RCU Forums - View Single Post - Ring Engine Compression
Old 05-07-2012 | 09:59 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Ring Engine Compression
I think (ok I'm sure) that if you RTFM from OS it will say they require very little break in.
All internal-combustion engines benefit, to some
degree, from extra care when they are run for the first
few times known as running-in or breaking-in.
This allows the working parts to mate together under
load at operating temperature.
However, because O.S. engines are made with the
aid of the finest modern precision machinely and from
the best and most suitable materrials, only a very
short and simple running-in procedure is required and
can be carried out with the engine installed in the
model.
