DLE 55 Ignition Plug Cap Question
Hi guys,
I have a fairly new DLE 55 that I just swapped the plug out for the recommended CM-6 plug. I noticed that after installing this plug that when the ignition plug cap is in locked position, it can, if rotated or pulled, slide down about 2 mm - guessing. There is no way it can come off. But it can move down a smidge. Other DLEs caps I've seen don't budge at all when rotated.
W8ye and others with a lot of gasser experience, what's your take on this. Ever seen it before? What I don't get is with the current plug cap design, it seems like it would be hard to maintain contact between the plug and the contact deep in the cap. Any little movement would present a gap and arching. See how much I don't know...
Anyways, just blathering at this point. Any help would be appreciated. I can still send the ignition back to Tower if needed.
Thanks!!!
