RCU Forums - View Single Post - Sebart Wind 110
Old 05-08-2012 | 04:02 AM
  #1703
lablover
Default RE: Sebart Wind 110
Question for you 110 owners. The one I just bought off a friend has the pull pull cables running under the Horiz stab and then to the rudder lower end. The manual shows it mounted above the horiz stab and higher up the rudder. Is this going to cause any issues? I'm sure I can re-work it but not sure if I should. The rudder seems smooth enough etc.
