Menu Start<span style="white-space: pre; " class="Apple-tab-span"> </span>:
<div>Auto +2<span style="white-space
re" class="Apple-tab-span"> </span></div><div>Pump Start Ramp<span style="white-space
re" class="Apple-tab-span"> </span>5</div><div>Glow Power<span style="white-space
re" class="Apple-tab-span"> </span>7,4V</div><div>Low Batt<span style="white-space
re" class="Apple-tab-span"> </span>7V</div><div>Start Power Ignit<span style="white-space
re" class="Apple-tab-span"> </span>130</div><div>Starter Power Fuel Ramp<span style="white-space
re" class="Apple-tab-span"> </span>110</div><div>RPM 100% Starter<span style="white-space
re" class="Apple-tab-span"> </span>17000</div><div>RPM Stop<span style="white-space
re" class="Apple-tab-span"> </span>20000</div><div>RPM Reconnect<span style="white-space
re" class="Apple-tab-span"> </span>18000</div><div>RPM Ignition<span style="white-space
re" class="Apple-tab-span"> </span>3000</div><div>Pump PW Ignition<span style="white-space
re" class="Apple-tab-span"> </span>18</div><div>Engine Min Flow<span style="white-space
re" class="Apple-tab-span"> </span>50%</div><div>EGT End<span style="white-space
re" class="Apple-tab-span"> </span>120°C</div><div>RPM Preheat K<span style="white-space
re" class="Apple-tab-span"> </span>5000</div><div>RPM Fuel Ramp<span style="white-space
re" class="Apple-tab-span"> </span>6000</div><div>Preheat Fuel<span style="white-space
re" class="Apple-tab-span"> </span>45%</div><div>Ignit Time Out<span style="white-space
re" class="Apple-tab-span"> </span>27s</div><div>Start Mode<span style="white-space
re" class="Apple-tab-span"> </span>AUTO COR
<div>
Menu Run<span style="white-space
re" class="Apple-tab-span"> </span>:</div><div><span style="white-space
re" class="Apple-tab-span"> </span></div><div>Full Power<span style="white-space
re" class="Apple-tab-span"> </span>122000</div><div>Idle SPeed<span style="white-space
re" class="Apple-tab-span"> </span>33000</div><div>Stop Peed<span style="white-space
re" class="Apple-tab-span"> </span>20000</div><div>Start Min<span style="white-space
re" class="Apple-tab-span"> </span>100°c</div><div>Max temp<span style="white-space
re" class="Apple-tab-span"> </span>840°C</div><div>ACC DELAY<span style="white-space
re" class="Apple-tab-span"> </span>8 at the beginning, and now at 6 and it's perfect</div><div>DEC DELAY<span style="white-space
re" class="Apple-tab-span"> </span>5</div><div>Stability Delay<span style="white-space
re" class="Apple-tab-span"> </span>100</div><div>Pump Limit<span style="white-space
re" class="Apple-tab-span"> </span>448</div>
</div>
