RE: Need Some help Regarding Cat build and the parts I received!!!
any idea on where the other pieces should go that are laid out.The 2 large flat pieces that are bulkheads one of them I dont think I need as it is bulkhead F there is 2 different ones and last blukhead I believe Is the transom.However all other pieces laid out I am clueless about.Also should I glue the 4 pieces that run bow to stern first?? then glue the bulkheads into those??I know in the picture It looks like there is 2 pieces that run bow to stern but if you look at the first picture at the bow you can see a line that dips below the bulkhead surface that line is another shorter 5/32 birchply that runs bow to stern just a shorter distance.
