RCU Forums - View Single Post - Test flight Procedures?
Old 09-02-2003 | 08:41 PM
Ron S's Avatar
Ron S
Default Test flight Procedures?
For CG position, stable vs unstable with a very subsonic aircraft, you should be able to use CG positions used on the real aircraft. Just don't use the extreme positions, and you might want to bias the CG forward, if anything. Good Luck! Test flying a model is one of the best parts - it gets your knees knocking!
