ORIGINAL: aerofly0610
I put a 14cell NIMH pack on my Hobbico starter and it has ALOT of torque, thoughts on bumping it up to 24v?
If I remember my High School Physics correctly, higher volts equals higher rpm. Assuming the windings can handle the higher volts and higher associated current. If the motor stops turning, beware....the voltage potential is converting 100% to heat. You just may weld something together....
