RCU Forums - View Single Post - mintor engines
Old 05-10-2012 | 09:26 PM
bcchi
Default RE: mintor engines
ORIGINAL: captinjohn
I got one and had to put it back in the box. The prop hub that holds the magnet...ect will not go onto the 10mm part of the crank. Seems like the hole in hub is 8mm. What makes me real concerned is in the meantime the warrenty or any guarantee just ticks away and soon will be gone. It may go back to seller.
Please post the engine serial numbers guys....like to keep up on that data too. Again if you own one...post the serial number. Thanks Capt,n[img][/img]
Questions?
Where did you buy this engine?
Why was the prop hub not on the engine when you received it?
How could they check the timing with out haveing the prop hub all the way on?
Who inspected this engine before shipping?
I am sure they will take care of this for you.
BCCHI
