ORIGINAL: SrTelemaster150
ORIGINAL: mike early
The cylinder wall and the piston on my .91 are scored in one small area. Is the cylinder wall coated with some other metal? Or can I try to buff it out?
Is it scored or does it have streaks?
If you can't feel it W/a fingernail it isn't scored.
If it is scored, it's toast.
The cylinder wall is hard crome plating over aluminum. (AAC aluminum piston/aluminum cylinder/chrome lined bore)
It's toast. can feel it with finger. far worse than what a fingernail requires...
