RCU Forums - View Single Post - New here
Thread: New here
Old 05-13-2012 | 04:26 PM
  #70
steed2-inactive
Default RE: New here
ORIGINAL: supertib
ORIGINAL: steed2
ORIGINAL: supertib
ORIGINAL: savagecommander
a machine is only as good as the operator.
Many times its the same operator running in the different classes.........many of our racers run both nitro and electric........ so it gives a great opportunity to compare the laptimes of the two different powerplants...And as a general rule nitro is the fastest machine on the track............I know you can not make a BL truggy match the Speed of my OS 25 Truggy without the BL going thermal ...in a short run it can be geared to be faster, but it cannot sustain that load without overheating.............I do have a radar gun that use, so I am not talking out my rectum, I also have a seasons worth of track data, even hosted the Canadian Nationals at my track........I actually like BL as its been great for business, they are less reliable then nitro and are thermalling motors and Speed controls quite often..........Also the hotter the climate the more issues the BL has, at the nitro challenge there was more no starts in the BL class by double then there were in nitro.............Its interesting, but all these facts are easilly checked and verified as all the results are posted......check the results from any of the big races and you will see the same trend..........
for reference my OS 25 truggy has a top speed of 55 MPH, and effortlessly pulls this gearing on the track..... I can run for 45 minutes straight without any thermal issues.........
I would like to know what brushless systems are going thermal on 4s. Albiet all things will have failures from time to time, but you always say the brushless sytems are going thermal where you race, but you dont hear about these problems from anyone else? Just wondering what systems are failing from sustained hard running on 4s? If thats the case,christ they wouldn't last one lap on 6s!
you should keep quiet unless you actually race son !
Watch the big races, look at the stats...BL has more NS then the nitro classes by a fair margin..
All systems fail...and if you guys took your BL truggies to the track against one of my 25's you would get pulled, and if you gear enough to pull me you will go thermal............
Son? oookay senile old man, was a simple question. forget it, another useless rcu thread .
