ORIGINAL: jzuniga
Thanks for the suggestions guys. In my limited experience, I've used the smallest servo arms (on jr servos) and the closest or second hole out. But in this application that won't work, but I think 3/4" would work.
Z
Z, I would try to give you pictures or measurements of my setup but I'm out on a trip series........
Suffice to say, I did my servo mounts so that the servo case lay just flush under the cover which gave the most clearance for the servo arm/pushrod clearance. I think 2nd hole out on a heavy duty JR arm. I did add some clearance to the servo covers by dremeling the slot farther back than stock.
-Mike
<br type="_moz" />
