RCU Forums - View Single Post - Hangar-9 Sopwith Camel Build Thread
Old 05-15-2012 | 12:39 PM
  #1152
jasona
Default RE: Hangar-9 Sopwith Camel Build Thread
ORIGINAL: tree2tree
ORIGINAL: flyallday
Bummer... they fly so nice unill you get on the ground. Easy to twatt.
Harry
I have figured out the landings on this little bugger!! I can nail about 90% of the landings now. Glide in as normal, then about 3 feet off the deck, increase throttle - in my case to about 1/4 to 1/3 throttle. With all the drag, it will continue to sink, but now there is plenty of air over the tail and I can control the direction. I keep the throttle there until it stops rolling. The roll-out is really long, but looks scale-like. The video I posted (post 1033) was just after I figured this out. http://rccd.org/Videos/11%2006%2009%20Camel%202.wmv . Take a look at landing number three.
Hope this helps some of you, although the 1/4 to 1/3 may vary depending on your power system. While the plane is stationary on the grass, advance the throttle until the plane just moves. You need a setting slightly below that for touchdown.
Now THAT is useful, thank you!
