RCU Forums - View Single Post - Futaba MC 9100A ESC
Old 05-15-2012 | 02:33 PM
woodie's Avatar
woodie
Default RE: Futaba MC 9100A ESC
I just checked the specs for the OS controller at Tower Hobbies and the specs listed say it a lower peak amp than the OS instructions list.
Tower Hobbies
SPECS: Cell Handling Capability: 14-36 NiCd/NiMH, 4-12 LiPo
Function: Forward-Stop-Brake-Reverse
Peak Load Current: 70A (85A 5 seconds)
PWM Frequency: 32kHz
Protective Function: Start protection/Low Voltage/ No Signal cut-off/
Overheat protection
Parameter Setting: ESC/ESC Programmer OCP-1 (optional extra)
Dimensions: 2.9 x 2.2 x 1.2" (73.4 x 56 x 31mm)
Weight: 4.4oz (124g)
Probably specs for a different controller.
It also says it has 'reverse' capability, not sure why we would need that for airplanes, but it would be spectacular on final approach.. ;-) Probably a carry over from another controllers specs.
Don
