RCU Forums - View Single Post - proper servo arms in jets?
Old 05-15-2012 | 06:40 PM
Craig B.
Default RE: proper servo arms in jets?
Hi Guys,
Just another point to enhance the performance of your set up....
End point adjustment should be used sparingly to adjust symmetry of control throws. If you want to reduce your total servo throw you should do it by reducing your dual rates, not with the end point adjustment. If you do it with dual rates, you compress the resolution of the radio over a narrower range of movement, rather than cutting off travel at each end. By reducing your rates you will achieve your aim of reducing servo throw in a way that maximizes your resolution over your desired range of movement. This is why most gyro manufacturers advise you to set your travel (ATV) at 100% and reduce your servo throw with dual rate reduction.
Hope that helps.
Craig.
