RCU Forums - View Single Post - Engine Bearings???
Old 05-16-2012 | 04:17 AM
  #33
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Engine Bearings???
ORIGINAL: James c harrell
No ideas on how to keep this from happening again??
Use castor oil, at least 30% castor to the synthetic oil. Run the engine dry at the end of the day and make sure the exhaust port is open. If you must use an afterrun oil wait an hour or so to allow any fuel to dry out., Most after run oils will not mix with the fuel and all will not mix with water. If wet fuel or water is in the engine the oil will trap the fuel or water against the metal parts.
