RCU Forums - View Single Post - Plans coversion from dwg to pdf
Old 05-16-2012 | 05:23 PM
davidgeorge212's Avatar
davidgeorge212
Default RE: Plans coversion from dwg to pdf
Do you have autocad or do you just have your plans in .dwg format? If you do have autocad, you can convert your plans using that program just by plottining it to a file instead of your printer. Other than that, I would say check with a local print shop. I have a local store that will convert any type of file into whatever format I want.
