ORIGINAL: gaRCfield
I don't know why I can't seem to post the data log, but:
RPM: Average=4427, Max=7556
Current: Average=19.3A, Max=66.7A
Power: Average=555W, Max=1821W
Volts: Average=29.7, Max=32.8
Temp(first time looking at this!): Average=93, Max=121
Can you do a full throttle measurement while holding the plane next time you go out? I would like to see how the 300kv Hacker compares to my 300kv Futaba on the 18x10. You're using a Xoar, right? Castle data log- My static #s are 29.7v 68amps and 7255rpm 2 seconds after full throttle on a fresh TP 20c. that was 14 1/2lbs of thrust. My Eagletree shows 6 amps less which I think is more accurate
