Now if you opinionated yo-yo's realy want to seee something crazy, look at 6D. Using a VPP with verical and horizontal thrust vectoring. Even if you don't add VPP to your plane a front mount motor with thrust vectoring is crazy. When you pull left rudder your engine turns 11-15 degrees.
The same with the elevator. I have a 36" EPP Foamy with dual thrust vectoring. it is awesome to fly. Two ways to mount servos. One with a push push horn to the elevator and one to the rudder. The other is with 2 extra servos. these must be minimum of 9 gram servos because of the Motors thrust The are also best mounted on the right side and bottom of the motor mount. Have fun.
Imagine how cheap flying would be if there were no ground.
