RE: Checking Ether content
Hi Greg,
Good point.
Also, I've heard more than once, that a test sample of one is practically useless!
When I did a similar test of popular glow fuels to determine the lube content, I used three samples of each fuel to minimize errors. The measurements were very consistent that way.
I would prefer using containers with more accurate markings, as the plastic medicine cups I used were only graduated in eighth oz increments, and those raised marks (cast in) were difficult to read.
The quart of Amsoil Cetane Booster I have should last me for several life times, so some separate tests for evaporation are likely to follow. <G>
Pe,
Hello again!
I've heard that theory before, and I may measure the ingredients separately next batch I mix, to see if I can detect any loss in total volume while blending Ether and Castor oil.
Thanks to both of you for your comments.
Bill
