tail wagging problem
Hi Chris, i would try a few things, one, lower the gain a bit....two, make sure the tail control rod is really smooth...and three, try a different servo; but before you do, what servo are you using? The futaba 9253? If you're using a standard analog, try getting a high speed digital, that will make a huge difference. Hopy you fix it.
Aaron
