RE: MCX2 servo not working??
Thanks for that. So the aileron servo is meant to move when there is rotor speed up? I can hold the MCX2 and throttle up and move the aileron control and I see no servo movement.
In flight I can turn and position 360 degrees, move backwards and forwards however it is very slight movement I can't however move it left or right, I suspect there are not enough sevors to do this???
Regards,
Ian
