RCU Forums - View Single Post - ISSUES WITH DYNUM SUPER CUB RTF BATTERY/CHARGER
Old 05-20-2012 | 10:48 AM
guver
My Feedback: (325)
Default RE: ISSUES WITH DYNUM SUPER CUB RTF BATTERY/CHARGER
Yes, the discharge rate has to do with the battery's ability to deliver voltage at certain currents. All you have to do is use 10C or higher. 20 C will be fine as the 10C is a minimum rating. You may also notice cooler battery and a bit higher voltage (power)
IN otherwords if the spec calls for 10C then you can use 10C or higher.
