RCU Forums - View Single Post - Plane Cleaning
Old 05-22-2012 | 01:05 PM
NEW222
Default RE: Plane Cleaning
ORIGINAL: Jim_Purcha
Unless it was given to you, it's going to cost at least $25.00 to recover the fuselage. Which club do you attend to fly from? Saints, WRCC or Steinbach? Just repaired and recovered a Tower Trainer 40 in ultrakote. I bought and flew the plane the past 4 years, so I thought it was worth recovering.
Jim
I bought it for the attached OS LA 40. Was going to trash it as I just wanted the motor, not sure why as I fly electric. Just wanted the frusteration i guess. I fly solo. In the fields around here, or at the big field at the cottage. It will be around $50 to cover as the whole thing is geting done. The pics were taken when it got here, and I sterted to carefully remove the rear area, and none of it stuck at all, so removed it all. Same with the wing. Started to carefully cut out the rib bays where damaged, then realized that it too was not sticking. So I will recover the wing, and probably dope up the fuse as it is solid balsa. If it flies, it flies.
