New version
http://calcrc.com/downen.htm
2.3.0
* check of updates is running automatically (can be switched off).
* added an option to save/load model setup to/from a template in "SPEED CALCULATION" tab
* new image in "Extra" tab - teeth count on servos as per the manufacturer
* added models: Traxxas Funny Car, Offna Hyper 7, Team Associated RC10T3
* added 9 models RC4WD (Boyer, Bully 2.2 Comp, Gelände, Gelände D110, Killer Krawler, King Of Hammer, T-Finder, Worminator 6x6, Worminator MOA)
* added tires Pro-Line Chisel 1.9" G8 Rock Terrain a Pro-Line Chisel 2.2" G8 Rock Terrain
* added servos: Corona CS238MG, Hitec HS-85MG, Hitec HS-5085MG, Fusion S316 BB/MG, Turnigy TGY-390DMH, Savox SC-1251MG, Corona DS1238MG
* corrected output from "SERVO" tab (print/copy/save)
* corrected output from "COMPARE MODELS" tab (print/copy/save)
* added tooltip help next to national flags
* corrected box where calculation is saved
* corrected data in SC Traxxas F-150 Raptor model
* corrected gear ration in Axial Wraith, Axial SCX10 model to 7,69
