RE: Avalanche xte
$55,ouch! Yes,it is frustrating when somthing costs that much,and still have problems.Unfortunately,there are no set screws on these,it's a pressed fit,and the yoke pivots on the pin.I'll have to give the shrink tube a shot,and perhaps the tape if that doesn't work. I know that the xte series is basically a factory conversion from the nitro platform,there's a whole bunch of unused holes in the chassis were the nitro stuff would have been mounted.Unfortunately,the drive train doesn't seem to have been beefed up accordingly. After researching the shared parts between the buggy,truggy,and monster truck,I have found out that Redcat is using the same exact bl motor as well as the same gear ratios on all three versions.I mean,a buggy uses say 4" tires,and the monster truck uses 6+" tires,they should have at least changed the gear ratios.The diff cups look like butter.Oh,and the truck is also on it's THIRD motor using the same 4cell setup it came with.I have had much better luck with the Caldera 10e,aside from the steering servo,it's been great.
