RE: Adhesive Question?
Frank, if the joint is prepared properly, an epoxy joint to a polyester fuse will bond better than a polyester resin will.......especially if a closed process was used. A polyester will bond well to polyester if an open molding process was used. Sand the area, clean it with acetone and bond away.
