RCU Forums - View Single Post - Tank placement question
Old 04-20-2002 | 06:28 AM
majortom-RCU
My Feedback: (40)
Default Tank placement question
The fact that the tank stopper is slanted up with standard upright mounting has little bearing on anything other than length of fuel draw from clunk to carb. I have seen suggestions that this length s/b nmt 7" but I have seen engines draw w/no problem at longer lengths. But obviously shorter length = better draw, esp since you will want to spend a lot of time hovering.
I like to have vertical center of my tank level with spray jet for equal head flying upright/inverted.
If it would save you an inch of fuel line length, I would not hesitate to angle the front of the tank down toward the needle valve, but still put your breather/pressure line at the top of the tank, even though the bubble w/b at the bottom.
I hate to splash cold water, but question the ST3000 as a good choice for this plane, as it is notorious for mid-throttle problems. There are solutions, but they are black art type. Much of the fun of the UltraHots depends on throttle management, and the ST likes to go either fast or slow, but doesn't like to be managed. If you are not adept at reworking ST carb, I hope you have access to someone who is.
