dented turbine cans ????
If the dent bothers you....Do this to fix it; Take the can off. Using a spoon, gently rub the spoon on the inside of the can across the dent while pushing out toward the outside of the can. The dents will disappear. The JetCat cans are pretty thin/soft. I've removed small dents pressing with my thumb instead of a spoon. The spoon just makes the job easier and smoother. This is the same method that companies like "Dents Away" paintless dent repair use to fix dings/hail damage.
Kevin
