I still won't be home yet; so can't work on the engine I will replace the diaphrams and see if thats the problem....and no it did not ingest dirt but incase there is no compression whats the best way to make sure that i have the correct amount, I made sure the engine is sealed.
ORIGINAL: badz
A engine needs only 3 things to start, compression,fuel and spark. So see which of those you don't have. Did the engine ingest dirt? If so you probably have no compression, hence it won't start, this is the most common reason for engines failing.
