You can use the method here:
http://www.airfieldmodels.com/inform...ate_gasket.htm
Used it without problems.
The head gasket is different; it's rather a shim to control the compression. You'll need one with thickness to suit your favourite fuel and glow plug. I can't give you guidelines since I never played with it but I am sure others in the forum can.
Cheers,
/Magnus
