RE: NGH 9cc Engine input???
Yes that is a good idea to check the magnet to ensure it is a top dead center matching the piston with the piston is all the way up. Especially after bolting on a propeller. The prop drive washer could slide or slip around the crankshaft as you are tightening up the prop nut.
