ORIGINAL: jollycub
.then why in the world put a 15CC's weight in the airplane?
Because I haven't seen a 10CC or 5 CC gasser?
In my original post, I suggested that I am doing a special covering scheme and do not want to get a lot of exhaust oil on it. I would like the sound of an glow or gas engine over an electric.
I'm sure there are lots of ideas about directing the exhaust away from the plane, but there will still get to be some on it. I would like to keep it as clean as possible. Having said that, has anyone seen 5 or 10 cc gas engines?
jollycub, you are facing a strong problem of less than adequate structural strength for such a weight up front.
BTW, a .15cc is equal to a .90 glow engine. You can figure, for reasonable close, that 10cc is equal to .60 cubic ins. engine.
Let me give you an example: There have been numerous examples, in this area, of big gassers departing the airplane. Mostly on ARFs but a couple were machines designed for lesser power plants than the ones the owners bolted on the front ends.
One I witnessed: Modeler hangs a G-38 on an ARF designed for .60 to .90 glow. He thought it was the King of Kings. Well he made a rather hard landing, but all looked OK. Then he started it up again, and was taching the engine. Well that engine had a mind of its own and desided to fly without the airplane. Modeler learned to live without the thumb and first two fingers.
THAT SIR IS WHERE YOU ARE HEADING! [:@]
I examined that firewall. I would not have put a .60 on it without significant additional structure on the fuse. ahead of the wing. Many ARFs are like that. I restructure maybe Overkill, but still have 2 thumbs and 8 fingers.
I have a Kadet Senior for initial training of newbies. It has some structural beefing-up in a few areas. It flies well on an OLD Bluehead ST. 40, 11-4 or 5 prop.
No matter your finish concerns, I strongly sugest that you redirect your thoughts about power application on your model. Painted finishes do well (1) use a good fuel-proff paint and/or a good fuel-proof overspray, and (2) if you clean them up well after a session. I have done and failed to have done such for some 65 years now. I well know the differences.
