ORIGINAL: Turk1
I want to warn you on GT 9 again because I just met same situation again on last weekend.
Pls. be warned,the prop driver of GT9 can be mount 180 degree forward that makes engine impossible to run.(Simply timing error).
So please check your magnet meets hall sensor during compression phase.
Good item to pass along. I saw this on mine when I was bolting up the prop and have it set right now.
Jeff
