RCU Forums - View Single Post - 1/12th Scale Edf Concorde
Old 05-25-2012 | 12:15 AM
Props4ever
Default 1/12th Scale Edf Concorde
Would a model of this scale and calibre being a edf model be allowed in this section of the site?
Length 17 Feet
Wingspan 7 Feet
Power: 4 x 90MM Freewing edfs with 1750KV motors
Expected weight: 25lbs-27lbs
Scale features: Lights, drooping nose with retractable visor, operating thrust reverser's, wheel brakes
Landing gear: Electric retracts with scratch built or modified from commercially available struts.
I started to work on this model 2 years ago, time went so fast!, it feels like i started it 6 months ago!. Model is being built from original factory drawings from Angelo French in France. Fuselage was scanned into 3d cad program and was made into 3d model n then into pdf files, I then made my own plans for it. Used foamcore as main base of the fuselage structure by making templates first and then cutting parts into sections. Wings are built from the original drawings with changes to thickness of the wing root ribs, other then that its from the original drawings.
Wing structure is built up from 3/32" balsa sheets, there will be spars that will be copulated with CF to take loads on the 3 main hard points. Trailing edge spars and 2 spars that will pick up nacelles will be made from 1/8" lite plywood. Few ribs and spars had to be generated as they were lacking on the drawing version i got. No big deal.
I do plan on making molds of this model post it's maiden flight and then make and sell short kits in future.
"I can't upload any pictures as every night i get these stupid "500 Internal server error." when i try to upload them, ill try later"
