RCU Forums - View Single Post - constant depth, tapered wing?
Old 05-25-2012 | 10:02 AM
Rodney
Default RE: constant depth, tapered wing?
Yes, this is quite common. Generally a favourable result as it works a bit like washout does, the wing section being a thicker percentage of thickness at the tip slightly lowers the stall speed of the tip section thus tends to allow lower speed without tip stall.
