RCU Forums - View Single Post - NGH 9cc Engine input???
Old 05-25-2012 | 10:14 AM
  #47
earlwb's Avatar
earlwb
Default RE: NGH 9cc Engine input???
True, but the 9cc engine has the fuel pump separate from the carb. Also the carb and engine seem quite content to draw the fuel OK at WOT if the pump pressure line from the engine comes loose on you. I had that happen a couple of times when I was bench testing the engine. I was thinking that if we can come up with a NelsonStyle bubbleless fuel tank we could use muffler pressure OK then.
