RE: Blade cx3 requires consistent left cyclic input.
Thank you for your assistance. Everything appears to be ok with the lower rotor head. I have made numerous fragile adjustments to the 3in1 with no luck. I am hoping the inner shaft is slightly warped and going back to stock on both shafts will do the trick. Fingers crossed. I am begining to notice some toilet bowl effect thats consistent with warped shafts bent flybars etc.
