RCU Forums - View Single Post - constant depth, tapered wing?
Old 05-25-2012 | 06:09 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: constant depth, tapered wing?
ORIGINAL: BFoote
Exactly. Depends on the airfoil in question.
Got the books.
Can download said profiles for free to anyone who is interested. Do a search for Selig and Illinois Urbana champagne university and you will find his site with the ability to download the data files. In zip form by the way.
As to a5BY why on stunt you can get away with it. Even in a stall you are generating lift. It does not matter in a control line if one wing tip stalls as centrifugal force from the line holds the model in the air and therefore you can tip stall all you want. Likewise said models are so overpowered it does not matter if you are flying in a 100% stall all the time. In fact for stunt you want the tip to stall quite often as it will make a snappier performer.
Last time I was at control line combat, no one was using a wing such as you guys describe. Everyone was using constant taper, constant airfoil properties.
Thanks for the informative post Speedy. It really helps further the discussion. <span style="color: rgb(255, 0, 0);">PS. wing loading has nothing to do with a stall, just means you can get out of said stall very quickly and easily. </span>
ORIGINAL: alasdair
It can also go against you.
When a wing section has more percentage thickness, or more percentage camber (or both) then its critical Reynolds Number increases. By that I mean the Reynolds Number (Re)below which the section has a big jump in drag coefficient and sometimes an early stall.
Check out various sections in Selig's books of wind tunnel tests and you will see what I mean. He tests at a range of Re, and you will clearly see the effect of reducing Re.
I have tried to attach a scan of Selig's test of the Eppler 374 section, from which you can see that changing Re from 300k to 200k makes little difference, but consider what happens if the root section re is 200k and the tip is 100k or 60k. Buy Selig's books (Soartech Publications), well worth while.
It is often best on models to reduce the section's thickness and camber when Reynolds Number is reduced.
On a tapered wing, the tip is obviously operating at a lower Re than the root, so this idea of keeping the top to bottom measurement the same while reducing chord will work SOME of the time, but at other times is asking for trouble. You need to check the performance of the section at the reduced Re (and who among you bothers?) or you could have problems.
Wing loading has everything to do with a stall. This is why heavier airplanes land faster. It does not have anything to do with AOA induced bubble seperation and I beleive that to be what you are refering to. A said airfoil will have seperation at the same AOA regardless of the wing loading however that is but one way to stall an airfoil. Another would be to stall your tip airfoil by cranking in alot of aileron while slow. I have flown everything from high performance sailpanes, pylon racing, pattern, IMAC and Helicopters and the only real experience is that in most cases airfoils don't matter much at our wing loadings. Granted with an aerobatic airplane you would want a symmetrical airfoil and for sailplanes a semi with a touch of camber. Eample, the flight difference between a S2048 and RG 15 was un-noticable to me. IMAC type airplanes have a wide difference in airfoil shape but none are a standout to being better than the other. Now if we had the same wing loading and same speed it would be a different story.
Not trying to be offensive but my question is: Are these little facts you state derived from R/C Model experience or are you quoting what you have read/learned on full scale theory/practice?
Oh and CL stunt airplanes do fly just as any other airplane and to get the " turn Radius " that Da Rock is refering to takes some tweaking of the airplane. I work with a CL guy that is one of the best, in fact he just showed me his Nats 2012 airplane yesterday. We have had discussions at length and have found that some of the things that adversly affect my airplanes do in fact affect his as well. We had quite a lengthy disscusion about tip stall and stalling the wings in the corners of a manuever. We both agreed that moving the CG aft and reducing the amount of elevator and flap throw would cure the issue. It worked like a charm. Now take an R/C model and try to do that optimum 5' corner radius and what would happen? The airplane would surely stall but the CL airplane does not. reason, the CL airplane has half the wing loading. Hmmmmm wing loading does influence stall.
