RCU Forums - View Single Post - 1/12th Scale Edf Concorde
Old 05-25-2012 | 09:36 PM
Props4ever
Default RE: 1/12th Scale Edf Concorde
[b]Left wing's build commenced tonight!...[/b]
Started building the left wing, for this wing i have used 1/8" lite plywood for wing's root rib. I want to see how this ply rib
will hold in comparison to 3/32" balsa rib on the right wing. If this lite ply served the purpose, then i will make another ply rib to replace root rib of right wing. I will be making lightening holes in the ribs of both inboard wings, i'm sure once these holes are made, wing's weight will reduce significantly yet "Zero" compromise of the strength of the structure.
ID:	1765900   Click image for larger version
