RCU Forums - View Single Post - constant depth, tapered wing?
Old 05-26-2012 | 07:04 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: constant depth, tapered wing?
ORIGINAL: BFoote
RC or CL with same wing loading/planform will both have a 5' turn. CL plans do not have half the wing loading. Why you believe this is a head scratcher unless you are equating the tensile force from the wire as a rule of thumb that it eliminates about half the loading on the plane. This is roughly true. Lift = force after all Force x time = power. Same power is required to turn and change the momentum of the aircraft in question. Difference is that the CL airplane has a wire that it can turn around due to centrifugal force allowing tighter turns as it does not have to do as much work to change its momentum and remain in the air compared to a regular plane. You will note that said CL plane slows WAY down(DRAG due to stall) when one does these radical turns whereas the regular RC plane does not as much.
As for your top paragraph, different airfoils etc don't matter nearly as much as the pilot in question. A good pilot can compensate for atrocious design. An excellent pilot can make an atrocious design look like gold. Especially in things like sailplanes.<span style="color: rgb(255, 0, 0);"> I have to laugh at the guys agonizing over the perfect airfoil</span>. Maybe for a NATS plane, but otherwise, ha. Same with pylon racing. Its 90% pilot 10% plane.
This is funny because in post # 9 you stated this " Exactly. Depends on the airfoil in question". Not to mention your whole second paragraph here is nonsense. I have competed for a spot on the US soaring team, have been a factory pilot for a helicopter manufacturer and worked up to the IMAC unlimited class. I am a fairly decent pilot but if my aircraft is not flying at 100% capability it shows in my flying. There is nothing worse then trying to fly a perfect manuever or a tight race course when you have to put in as many correction inputs as you do control inputs. It makes for a much higher pilot workload that even the best pilots can't hide.
You seemed to avoid/ignore my previous question. What model experience do you have?
