RE: Why the near obsession with over powering airplanes?
Speed doesn't cause flutter. Most flutter can be prevented for almost any speed by sealing the gaps along hinge lines. If you don't cover over the gaps, make sure the control surface is very straight and has even spacing all along the hinge line. There should be no slop in the linkage.
