RCU Forums - View Single Post - How to install a kill switch in a 6ch setup that uses already a dual elevator???
Old 05-26-2012 | 07:09 PM
earlwb's Avatar
earlwb
Default RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
I would use a switch off the throttle channel, and when you move the servo below idle it pushes on the switch killing the engine. You can use a leaf switch with a sensitive lever that you can push against with a wheel collar on the throttle pushrod.
