hello
I got a new rx-tx today from hobbyhot . it’s the new model where you have Transmitter Li-Po Battery better from FS-GT3B
You can use th HK rx GT-2
You have to do a parameter for the throttle configuration : channel 2 REV (REVERSE) and TRIM F30 FOR FORWARD.
I paid the 20 /05 and I received in france the 25/05 whoooo !!! very fast
http://www.hobbyhot.com/FLYSKY-RC-Mo...ver-TS897.html
FLYSKY RC Model FS-GT3C 3ch 2.4GHz LCD GT3C Transmitter & GR3C Receiver TS897
Introductions
AFHDS (Automatic Frequency hopping Digital System), is developed by FLYSKY for all the Radio Control model lovers and is patented by FLYSKY at home. The system is specially developed for all the Radio control models, that offers super active and passive anti-jamming capabilities, very low power consumption and high receiver sensitivity. With extreme rigorous testing by engineers and studying the markets for years, FLYSKY AFHDS is now considered to be the one of the best systems available in the markets.
Specifications
Channels: 3 Channels
Model type: Car / Boat
RF Range: 2.40 - 2.48GHz
Bandwidth: 500Hz
Band: 160
RF Power: Less than 20DB
2.4G System: AFHDS
Code type: GFSK
Senditivity: 1024
Low Voltage Warning: Yes (Less than 3.7V)
DSC Port: Yes (3.5mm, Output: PPM)
ST Range: 90
TH Range: 45 (F:30, B:15)
Charger Port: Yes (USB)
Power: 3.7V (800mAh)
Weight: 346g
ANT Length: 98.5mm
Size: 151 x 183 x 116mm
Certificate: CE, FCC
Package Includes
1 x FS-GT3C Transmitter
1 x FS-GR3C Receiver
1 x Charging USB Cable
1 x 800mAh 3.7V Transmitter Li-Po Battery
1 x Extra Handle (Large Size)
1 x English Manual CD
1 x Color Box
