RCU Forums - View Single Post - Quick question on Solder Clevis
Old 05-26-2012 | 09:47 PM
combatpigg's Avatar
combatpigg
Default RE: Quick question on Solder Clevis
You can't beat silver solder for a lot of things. The only warning is over heating some things and then losing the temper of the metal. If the job ends up looking pretty...then it should work OK.
Just use as little heat as possible to get it to flow.
