RCU Forums - View Single Post - How to install a kill switch in a 6ch setup that uses already a dual elevator???
Old 05-27-2012 | 04:01 AM
goirish's Avatar
goirish
Default RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
ORIGINAL: coralcape
You can also mount one servo higher or lower than the opposite and invert to work in the same direction. Good luck, red
I have several planes set up this way and never a problem with any of them. In fact build a scratch built sweet and Low giant stick and setting up the elevator that way.
