RCU Forums - View Single Post - Monsoon XTR
Thread: Monsoon XTR
Old 05-27-2012 | 08:01 AM
Dads like rc too
Default RE: Monsoon XTR
ORIGINAL: MaddMark
Thanks For the info.
This will be my first nitro truggy and I plan on general bashing in the yard when too windy/hot/cold to take the hour long trip to the flying field.
Sounds like I just need to avoid trees and other such solid objects and enjoy.
I heard that I should increase preload on all shocks as its so heavy. Your thoughts?
I'm not a racer but to me for general running around and jumping, the factory shocks work well. The big issue is the weight. The Monsoon is very heavy. I find with a good run it launches well but is extremely nose heavy, so lots of throttle in the air making sure your freewheeling when landing. The torque is there for short launches, problem I have is getting traction. In the grass all four wheels just spin off the line. Power slides are no problem with this machine. Even on the pavement it breaks the wheels loose. As far as avoiding things, I just mentioned what parts I thought could have been stronger. It's still taken its share of hits without a blemish. I still say for the money it's well worth it. Try to buy any nitro from Traxxas in this price range and you'll be going home with a nitro rustler for about $50 more. Like anything else out there, there's room for some mods. I like the idea of CVDs all around. Redcat sells them cheap enough. I would also like to carbon fiber anything I can to try and get rid of some of the weight, not because the stock components aren't tough enough.
