RE: Engine Quits when I squeeze throttle
You can't break it in on the block. You need to put a load on the engine or it will just rev out. 1st tank at idle is ok. Some even like to run two tanks at idle, but trying to run it on the block is a waste. You'll never get the engine hot enough for sleave expansion.
