RCU Forums - View Single Post - 3D out of the box?
Old 04-21-2002 | 11:57 AM
Bluto
Default 3D out of the box?
flmgrip, The tail rotor shaft should be drilled and threaded on the end near the pulley, the set screw goes in there. Are you missing the set screw? Or you may have the older style tail shaft in your kit, the old style used a roll pin to hold the pulley on the shaft. Good Luck!
