RE: Powerbox Cockpit SRS Problems
Mark,<div>upon start up I get the normal consumption screen, then as anal as I am, I switch to the frame loss screen to see whats going on. Once I forgot to revert back to the consumption screen and the gears did not work. Mark Hinton was on the stick as it was the cougar and when the gears didn't go up he inquired if I had switched to the frame loss screen. He said that it has been noticed that when this screen is active, the gears don't work. I spoke to RIchard about this and he confirmed that this is correct.</div>
