Best Heat Sink for HPI Nitro 3
With either engine you should not be having any cooling problems.If you are check your needle settings to make sure the car isn't running to lean it might save you some cash.My 12Rss never got above 260 even after several High speed pass's with the body on so thier is no reason it should need a better cooling head if it is tuned right.
